Mini T keeps going?
1FSTLS1
Mini T keeps going? - 07.12.2009, 08:08 PM
Just got a used Mini T the thing will have the throttle stick and keep going out of controll has a mamba motor and speed controller and losi rx and tx. Batterty light in controller is green and both antennas up? Is this a common problem do I have a liquid dammaged reciever?
__________________
07.12.2009, 08:27 PM
Used? not working properly? Funny that...
I would say reset the esc and reprogramme the radio to it, paying attention to the throttle trim and what-not. After that, check the tx batts are fully charged/ fresh, and that there are no loose or damaged connections (or antenna damage). Beyond that =
1FSTLS1
07.12.2009, 08:36 PM
Reprogram = read manual. Thanks I ll try that. No way to do this on with the laptop?
07.12.2009, 10:21 PM
first check throttle trim. I've also had this happen when the receiver was too close to the esc, it could be interference
1FSTLS1
07.14.2009, 10:45 AM
Any other ideas?
07.14.2009, 11:58 AM
if you've tried everything we've suggested and the problem persists I would try a different reciever. It does remind me of interference though.......
07.14.2009, 01:08 PM
Could be a bad esc... same problem happened to my old brushed 18t controller after going thru a puddle. If your steering works fine it leads me to believe it's not the rx...
