RC-Monster.com Now Carries Feigao 380C Motors!
Batfish
Batfish's Avatar
RC-Monster.com Now Carries Feigao 380C Motors! - 02.04.2006, 11:46 AM
Now at RC-Monster.com - Feigao 380C Sensorless Brushless Motors!
These motors have a built-in heat sink and a nice finished look. Great for 1/10th scale applications, they have a 1/8" shaft with a flat spot and a "540" bolt pattern, which means they'll bolt right up to most motor mounts! Available in several different "kv" ranges, you're sure to find one to suit your needs!
Now in stock at a fantastic price, you can find them here:
http://www.rc-monster.com/proddetail...AO_380C&cat=20
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
ygguB naM
02.04.2006, 03:31 PM
Is it as fast as a hacker c406t?
squeeforever
squeeforever's Avatar
02.04.2006, 03:41 PM
im pretty sure there escensially(sp?) the same thing.
MetalMan
MetalMan's Avatar
02.04.2006, 04:08 PM
They are pretty much the same, just about 1/3 the cost ;). They may not be as efficient (which would slightly affect performance), but for the price they are more than good enough.
Batfish
Batfish's Avatar
02.05.2006, 12:02 AM
Also, the 540C 9L motor has been added!
http://www.rc-monster.com/proddetail...540C_9L&cat=20
Joe
rchippie
rchippie's Avatar
02.05.2006, 12:33 AM
How do the 380 size BL motors compare to a 540 size BL motor ?.
REAL MEN RUN BRUSHLESS
Superemaxx89
02.05.2006, 02:31 AM
will these fit into the losi mini LST?
Will two?
squeeforever
02.05.2006, 04:40 AM
im pretty sure there to big but i would recommend the mamba or a tekin system. i was thinking of trying the mgm 25 amp controller with a tekin or mamba motor. thats always an option.
MetalMan
MetalMan's Avatar
02.05.2006, 01:32 PM
The regular 380 motors should fit, but these are the "C" version which have 540 motor mounting holes.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.06.2006, 08:17 PM
Their the same width as a regular 540 because of the heatsink, but they're a few mm shorter. I have the 380c 9t. It's good for 50 mph on 3s lipo in most 1/10 scale applications.
Area 52 Ranch Raceway
T.R.C.R.
coolhandcountry
coolhandcountry's Avatar
02.06.2006, 08:57 PM
Would a 380 be good for a rusty?
Peace!
Country
Help support the
Rc-Monster
Buy here
MetalMan
MetalMan's Avatar
02.06.2006, 09:24 PM
Yes, it would be. For 6-8 cells, the 380C 6L is a great motor. Like SpEEdyBL said, 380C 9t for 3s Lipo. Then 380C 13t for 4s Lipo.
