Which spacers go where on 2650?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
Which spacers go where on 2650? - 07.16.2009, 11:54 AM
I opened up the motor to clean the bearings and I forgot which spacers go where on the rotor. From the wear marks, it seems like the short spacer goes toword the ouptput shaft end, but it is hard to tell. I don't know if it is just me if the shaft sticks out longer than normal as it measures roughly 21mm from the mounting face. Also, where can I find replacement bearings? One of them seems a little grindy.
Area 52 Ranch Raceway
T.R.C.R.
Hockeyplaya20
Hockeyplaya20's Avatar
07.22.2009, 12:48 AM
If i remember correctly, the front has the short spacer, the rear has the long spacer.
Bearings used are "Oversized ABEC-1 front and rear" i cant seem to find them online.
6s MMM E-Revo l Rustler VXL l Stampede XL-5
blueb8llz
07.22.2009, 04:17 AM
how often do you guys change the bearings? i didnt even know we had to. do you guys oil the bearings too?
SpEEdyBL
SpEEdyBL's Avatar
07.24.2009, 03:00 AM
The problem is the dirt tracks that I run on. Dirt seems to very easily find its way into the front bearing.
T.R.C.R.
