New Slash With MM/VXL on 3s!!!
emaxx 101
New Slash With MM/VXL on 3s!!! - 07.19.2009, 01:18 AM
Hey guys just took my new Slash on it's first run....WOW! it flys . It has a Velineon motor and Mamba maxx esc in it
running on a 3s TrueRc batt. Geared 18/90. It was about 65f outside, battery = 96f, esc = 117f and motor = 155f. I have one question, is 155f pushing it on a velineon motor? I will try a 23 tooth pinion and see if I was undergeared. Pic/Videos within the next 2 weeks.
07.19.2009, 01:23 AM
Not really- 155 should be okay. Try gearing up a bit though.
emaxx 101
07.19.2009, 01:27 AM
Ok thanks!!!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.19.2009, 01:43 AM
Yes, 155F is A Okay for a Velineon.
You got a vid? Don't make me get out the "This thread is useless..." pic.
emaxx 101
07.19.2009, 01:55 AM
I will, but I won't be able to until this weekend. I'll shoot it In all high def with a 23t pinion.
zeropointbug
Z-Pinch racer
07.19.2009, 02:32 AM
Nope, I'm afraid you get the useless badge...
zeropointbug
Z-Pinch racer
07.19.2009, 02:33 AM
And videos...
emaxx 101
07.19.2009, 03:04 PM
There you go, Vid will come later.
emaxx 101
07.26.2009, 02:48 PM
Hey, just took it out again. Ambient temp was about 79f. The motor was 162f, the esc 150f and the battery 95f at around 10 minutes. Gearing was 23/86. Start power at low, timing at lowest, braking at 90%, punch at 40%. Is this ok? Does anyone know the maxx temp of the vxl motor?
zeropointbug
Z-Pinch racer
07.26.2009, 03:35 PM
162F is still within safe range, but 152F for the MM? That seems quite high, considering what it is pushing around.
scarletboa
scarletboa's Avatar
07.26.2009, 03:37 PM
i would go with a 19-21t pinion and either a 83 or 86 tooth spur.
emaxx 101
07.26.2009, 04:10 PM
Uhh the 152f was the esc heatsink temp, the actual case was about 120 f. Should I refer to the esc temp as the heatsink or case temp?
emaxx 101
07.27.2009, 12:50 PM
Finally got time to shoot some video . Gearing was 21/86. Youtube wouldn't let me use any good music :(.
[YOUTUBE]
emaxxnitro
emaxxnitro's Avatar
07.27.2009, 03:39 PM
heatsink the case is irrelevant
808E
nitrostarter
nitrostarter's Avatar
07.27.2009, 03:52 PM
I want a MTV crib's tour of that house... lol
N. Rustler conversion
