Increasing runtime:
$w!ft
Increasing runtime: - 02.05.2006, 06:42 PM
Whats the best way to increase the runtime of a brushless setup:
IE;
Would 20 cell gp 3700's be better than say 4000mah lipos???
Right now im running 16 cells and im just considering more runtime+powah!
Cheers.
Superemaxx89
02.05.2006, 06:45 PM
unless wired parallel, more gp3700 won't give you more runtime. But you will get more power.
ygguB naM
02.05.2006, 06:46 PM
The li-po's give way better run time than nimh but you could get better li-po's than than that.
maxxdude1234
maxxdude1234's Avatar
02.05.2006, 06:50 PM
Geared down 20cells would give you slightly more runtime than 16cells. Personally I would reccomend saving up a getting a good set of lipo's (4000+mah)
dabid
02.05.2006, 06:51 PM
Thing is though, with more Nimh cells, there's less load on each one, so runtime actually does go up. This would be the reason that guys running 18 GP2200's get about the same runtime as guys running 12 GP3300's.....up to 15 minutes or so.
EDIT: Maxxdude kinda said the same thing I was thinking........
$w!ft
02.05.2006, 06:56 PM
Whats a really good lipo pack?
maxxdude1234
Serum and I had a long discussion about this, and adding more cells can increase runtime if geared down - so that the truck goes the same speed on 20cells as it did on 16cells. But if the gearing is kept the same, runtime will decrease (but speed obviously speed will increase).
Swift, your best bet is with lipos (lighter, bigger capacity, no voltage sag under load)
MetalMan
MetalMan's Avatar
02.05.2006, 08:32 PM
In case anyone is wondering why the runtime will decrease if you add more cells and don't gear down, it is because the motor will pull more amps due to the increased voltage.
$w!ft
02.06.2006, 08:39 AM
any1 know what some really good lipo packs are?
MetalMan
MetalMan's Avatar
02.06.2006, 09:33 AM
How much do you want to spend?
virusss
virusss's Avatar
02.06.2006, 09:39 AM
You council the 20 EVO Flightpower www.flightpower.co.uk
$w!ft
02.06.2006, 12:50 PM
Thoses are only 3300mah, im was looking for 4k ish, and im looking to spend 600$ . But you guys know about lipo, so maybe thoses 3.3k packs are better.
boss 302
02.06.2006, 04:51 PM
a 3300 lipo would be better than a 3300 NIMH cells
also what currency are those prices in
$w!ft
02.06.2006, 05:03 PM
Thoses are pounds. So you are saying these are some of the best packs out there?
Chase023
Chase023's Avatar
02.06.2006, 05:41 PM
$600?? I wish I had that to spend on some lipos heh..
Well I think you should look into a few brands before you decide on one, tho those evo packs look pretty good from the specs.
Embrace the Speed!
 Send a message via ICQ to Chase023 Send a message via AIM to Chase023
