G2R Gearing
CCristo
G2R Gearing - 02.05.2006, 10:42 PM
Hi Guys,
Does anyone have any suggestions on what gear ratio to run on my G2R with a 7XL on 12 cells? I have a 51t spur.
squeeforever
squeeforever's Avatar
02.05.2006, 11:30 PM
i would say a 14 tooth pinion should be close.
crazyjr
crazyjr's Avatar
02.06.2006, 01:54 AM
I'm not sure about metric pitch gears but i would start with an equivilent to a 16/66on 32 pitch gears and work from there. hope this helps
CCristo
02.06.2006, 10:33 AM
Ok, thanks guys. I have a 12t on order, so that'll get me close.
Batfish
Batfish's Avatar
02.06.2006, 12:06 PM
Chris,
I have a 12, 14, and a 15t 5mm bore Mod1 pinion(s) that you can try since I'm not using them...yet :003:
I'll try to remember on Thursday night.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
