Neu 1400 series
OZ-RUSTLER
OZ-RUSTLER's Avatar
Neu 1400 series - 08.07.2009, 04:31 AM
Any one know if the Neu 1400 series lengths correspond with the 1500 series?
http://www.castlecreations.com/produ...rs/nm1400.html
Thanks
wallot
wallot's Avatar
08.07.2009, 05:33 AM
Neu 1400 series use 1500 series rotor so 1415 is as long as 1515.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
 Send a message via ICQ to wallot
nitrostarter
nitrostarter's Avatar
08.07.2009, 10:19 AM
Yes sir the length are the same, just the diameter of the can is 36mm.
N. Rustler conversion
scarletboa
scarletboa's Avatar
08.07.2009, 03:44 PM
so, for example, a 1515 1y has the same output as the 1415 1y right?
wallot
wallot's Avatar
08.07.2009, 03:50 PM
no based on new Neu ratings 1515 series are 2500W and 1415 2200W
Radek
*EX-10 Eurus*
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.07.2009, 06:41 PM
Peak power should be the same really (if the core/stator is the same), just the continuous power output would be lower because of less area to dissipate heat.
