CRT.5 and 2.2 and/or 2.8 truck wheels and tires????
g-townmach
CRT.5 and 2.2 and/or 2.8 truck wheels and tires???? - 08.08.2009, 11:08 AM
Have been running my brushless crt.5 for a while and the stock tires are shot. I know alot of people run 2.2 truck wheels and tires, but do you need the fronts of rears??? Or do you need both? I know the stock .5 wheels dont have a different offset for rear or front. Also, would these 2.8 wheels and tires work on the crt.5?? They're 30 series prolines for rustlers and stuff... http://www.amainhobbies.com/product_...-Electric-Rear
I just would like to know if i can run rears on all 4 corners of my .5 or should i run fronts? Thanks in advance!
david lamontagn
08.08.2009, 02:22 PM
Thant's exactly this 2.8 proline i have on my crt.5, but my it's mounted with bowtie tire, but your choice is #1, you'll lobe them
08.08.2009, 03:21 PM
On both my crt.5 I run Gladiator tires on slingshot 2.2 FRONT rims
david lamontagn
08.08.2009, 04:32 PM
You slingshot are traxxas wheel i suppose??
And you say it's front, this front of the electric stampede/rusty?
Thank you!
Your crt.5 is realy sweet Magman, i'll recieve my rcm extended frame next week and put my motor and MMM on it, with thee 5s lipo and post you some pics.
I'll not have my extended body yet (don't know which one to take between the proline jato, associated T4 or Losi xxx-t). So i'll post pics with stock body on.
08.08.2009, 07:39 PM
Thanks for the kind words....Actually David, the rims are these....http://www3.towerhobbies.com/cgi-bin...?&I=LXMV45&P=7
And the tires I used are these...http://www3.towerhobbies.com/cgi-bin...&I=LXDX67&P=ML
Please post some pics when you are done...and if you are going to run it on 5s.... Mine is plenty fast on 3s so 5s...wow!
08.08.2009, 08:06 PM
I use these: Pro-Line Racing 30 Series M2 Bow Tie Tires Mounted on Chrome Rear Torque Wheels! #1138-12
http://cgi.ebay.com/ws/eBayISAPI.dll...ht_1195wt_1165
david lamontagn
08.08.2009, 10:13 PM
exactly the same setup as me
tkhoo
11.06.2009, 04:22 AM
hi guys, can I use 1/8 scale tire on crt.5? I know I need to mod the wheel hub but any pro and con? Thanks.
