Hey fellas =)
Picked up this truggy this morning, and got started this arvo on converting it... Happy with the progress, considering i only had a short time to work on it before the missus put her cranky pants on...
I usually do a full documentary with pics and all step by step, but was too lazy, and didn't have the time, so just have a couple pics to show the basic layout so far...
I pretty much copied gtxracer's setup, but am gonna be full time 4s lipo :)
I had to flip the front upper steering plate, so that i could move the front chassis brace to the right hand side of the centre shaft, as i needed clearance for the motor.
I placed the front brace slightly different here, already knowing he ran into problems at the servo... I hacked up some of the front chassis brace to clear the front centre dogbone and didn't touch the servo at all...
I have installed a couple posts to hold the lipos in place, and I also cut out a couple slots in the chassis for the velcro straps to pass through the chassis to keep the packs in place.
I also had to flip the centre diff round, and cut another slot for the diff gear to clear the chassis... This was just to make a little more room for my batteries mainly...
I have the right hand side battery 'standing' high, as it was just easier to get it into a nice, neat place - i am not concerned about the extra height on it... I am unsure if I should do the same on the left pack and bring it closer to the centre line, or if I should just keep it as is... What do you guys think??
I also cut the servo plates, and removed the radio box, as i wont need it.
I will get hold of a 17-1900kv motor for this one, and will run the Elektri-Clutch like the rc8 buggy. I also need to make some plates for the tekno motor mount for adjustability...
I am going to mount the Speed Passion 1/8 ESC in this one just above the steering servo.
The RX will go just in front of the steering servo on the mud guard, or next to the 'standing' lipo, also on the mud guard - will see when the arm is on the servo.
There is room for the transponder mount where it mounts normally in the stock position... i cut that part of the servo plate before i realised i could 'stand' the lipo up -lol-
Things to do before drive time are....
*Install the ESC
*Get a motor/make mount plates for tekno mount and install that
*Add radio gear and a 7955tg for steering... (the spektrum servo in the pics is just for mock up)
*Hack up a chopping board, then shape it and screw it to the bottom of the chassis - this is going to cover and protect the velcro straps on the underneath side of the chassis.
I thought i was gonna need battery trays, but looks like i worked my way around that one =)
So - enough talk - here are some pics of what i have so far...
this is my first truggy, and can't wait to see how it goes against te local nitros... They already are impressed at the buggy, so hopefully this knocks em over too, and hopefully converts some at the same time! :D
what do you guys think? :)
