MMM problem
alport
MMM problem - 09.11.2009, 04:17 PM
My monster esc have a problem. When I applying throttle motor runs intermittent and sometimes don't run. during that the red and green leds flashing on the esc . What is the problem? how can I solve it?
brushlessboy16
brushlessboy16's Avatar
09.11.2009, 04:57 PM
http://rc-monster.com/forum/showthread.php?t=20020
Open your eyes
its stickied in the top of the CC subforum.
reset your trim and recalibrate
Marvin
THE Paranoid Android
Marvin's Avatar
09.11.2009, 05:08 PM
There's only one problem. In all those examples in the linked thread, it doesn't cover red and green, just red or green.
Unless red or green means alternating, and not either only one of the two colours ever comes on. If so, just ignore me. I'll shut up.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
alport
09.11.2009, 05:49 PM
green and red light flashing on the same time. The link doesn't include that.
bryan
bryan's Avatar
09.11.2009, 06:21 PM
Have you tried reprograming that poor little guy.are you saying green flashes on forward,and red flashes on rev. If both flash at the same time i think you need to contact castle.
bryan
bryan's Avatar
09.11.2009, 06:24 PM
May even be your transmitter or reciver screwed try another if you have access
alport
09.12.2009, 02:00 AM
I'll try another receiver. both green and red flashing at forward full throttle.
alport
09.12.2009, 09:32 AM
HI again
I found the problem. I opened up the esc and saw that a little electronic part brake off. I can't find the missing part. Now I need your help to repair it by myself. I don't want to send the esc to Castle to repair because I live in Turkey and that will cost me much time and money. On the attached pictures you can see the missing part. Can anyone take a picture like that of his working esc. I'll look the local electronical shops to find this missing part.It's very easy to open the box of esc here is a description.http://www.castlecreations.com/suppo...nster_case.pdf
Your help will be much appreciated.
ID:	7694   Click image for larger version
09.12.2009, 12:00 PM
I kinda doubt you'll find the part you need in your local electronics shop, and its even harder to make a good soldering job on the esc as Castle use special high temperature solder- more likely to damage the esc and surrounding components through the heat.
As it is, there are a few good pictures around this section-
2244
T35HV
hard to make out, but thats what you're looking for, its in the bottom left of that picture, upside down. Maybe Castle can send you the missing bit, or you may be lucky and find it online, but I think you may end up having to spend the money to send it in and get it repaired...
emaxxnitro
emaxxnitro's Avatar
09.12.2009, 01:20 PM
it falling off may have fried something else, best send it in
808E
brushlessboy16
09.12.2009, 01:35 PM
Edit- Neil posted my pics
you bum.
Myself and my teammate had components fall off within 20 minutes of eachother...
09.12.2009, 04:37 PM
Har har har...
himalaya
himalaya's Avatar
09.16.2009, 01:47 AM
alport, your missing part was a tantalum capacitor for the internal 12V generator, 22uF16V. Find one and solder it to the PCB, pay attention to its polarity when soldering.
brushlessboy16, your missing part was a muti-layer inductor, around 100uH. My first MMM V2 had this component failed also, just failed, no broken off, it had an internal short circuit making the motor no any action(no spin, no beep) but the LED and Castle Link still work. Go find one that little component and solder it back on, get a wire wound inductor if possible, much more reliable.
....What a Blue Sky....
phatmonk
RC carbon junkie
phatmonk's Avatar
09.16.2009, 06:09 PM
Wow back to the cushioning issue in the bottom of the MMM case.You would have to land some pretty hard landings to do that.I have the 1st generation V3 MMM controler and have trashed on it and it stll works perfect.I use the Traxxas MMM mount bracket and thick 2 sided tape.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
J57ltr
09.17.2009, 06:08 PM
It's amazing how many parts Castle uses that we also use at work. We have a lot of problems with the Tant. caps shorting out. Next the Electrolytics will start pooching out.
We have a switching power supply that is made by another manufacturer and after 6 months to 2 years they fail. They are all low ESR. Jamicon and Hermei are the ones we have the most problems with, and switched to Nicholsen(sp) and stopped having problems. There are 3 470 uf 1 1000 uf and a 2200 uf that always fail at the same time. Although we still have a bunch still come in for repair that used the old caps before we found the problem. In the last 2 years we have yet to have a repaired board come back (with a problem), at least I don't consider a blown fuse with the spare right on the board a problem since it fuses the output of the power supply itself, so if it's blown it's another card and it's usually a Tant. cap or one of the other surface mount caps that are shorted.
Jeff
