Hobbywing BEC
dfreshrc
Hobbywing BEC - 09.14.2009, 09:16 AM
How is the Hobbywing BEC. I got a 150Amp version and was wondering if the BEC can handle more than 12 cells.
I know with my Mamba MAx if I go over 12 cells it is suggested to run an external BEC should I do the same for the Hobbywing or can it handle the extra juice?
Thanks
09.14.2009, 10:04 AM
The HW 80A and 150A use a switching BEC, the MM uses a linear BEC, so you're fine.
dfreshrc
09.14.2009, 01:12 PM
Thanks for the quick response
Glad to know this will work I can put the money for the BEC to some new LIPOs instead
Thanks again!!!
scarletboa
scarletboa's Avatar
09.14.2009, 09:52 PM
Thanks again!!!
i think you might be surprised how cheap you can get lipos for nowadays. the turnigy series batteries from hobbycity.com are actually cheaper than even mid-grade ni-mhs.
you can get a 5000mah 20c 2s pack for $20! the 3s version of that pack is only $30.
