How much you need mAh for one race? -
09.19.2009, 03:46 PM
If this has been discussed before, link me there.
How much you need mAh in one 45min or 10min race with truggy??
I assume there must be atleast one battery swap in 45min race.
4S is in rules, so mAh with 4S lipos.
Motor used would be "truggy" spec, like Tekins truggy motor.
I want my truggy as light as possible, so this info is in big role.
that setup would probably use about 350-450mah/min as a rough estimate.
If you can make 45 minutes on one battery then good for you, but the extra weight will cause the motor to run hotter, bringing your runtime even lower.
5000mah packs seem to be a good balance between run time and weight.
45 minute mains you would probably need 3 battery swaps
Well, i want motor that is sensored, to get best precision.
In 10mins i dont want to change battery, well that would be what im running in race.
So 350-450mAh in minute, and i would need 4000mAh minimum, 5000mAh would get me to finish line.
