Antenna Setup for Speed Runs
kazuaki
Antenna Setup for Speed Runs - 09.23.2009, 11:30 PM
What are others doing with their receiver antenna on speed run setups? My Ko Propo KR-407S 2.4Ghz receiver has an 8" antenna wire. For speed runs I need to have good range. Of course I can always do the standard vertical antenna tube. Is there another setup that might keep the antenna inside the body and get similar range? I've seen some spektrum receivers with super short antennas, but this one is a full 8". Ideas?
