Conversion questions
naynay12
Conversion questions - 09.25.2009, 04:34 AM
Just a couple of questions,first off i have a 2s and 3s turnigy pack,they are both the same discharge and mah,i haver a turnigy accucel-6 charger.Can I charge the packs, aswell as run them together by using this connection ? http://www.hobbycity.com/hobbycity/s...ad_(2_x_3S)6S_
Also i will be running 5s with the mamba 2200kv motor and the original 47t spur on my savage 4.6 conversion,and probably a 20t pinion.Will the hpi 20t pinion hold up ok?
Also at the moment i have the 2 speed tranny,now for it to hold up,will i only need the "HPI Idler Gear 44t/Shaft Set",to convert the tranny to one speed and it should hold up right??
pinkpanda3310
pinkpanda3310's Avatar
09.25.2009, 10:50 AM
The connection your looking at is for 2 times 3s batteries. You have a 2s and 3s, yes? This link should help explain some of what you want to know http://www.rcgroups.com/forums/showthread.php?t=932319
naynay12
09.26.2009, 05:43 AM
Thanks i have cleared that part up, btw yes,i have a 2s and 3s.
So it would be great if someone could clear up my other 2 questions so i can buy the parts asap.
The reason why i want to know if the hpi pinion will hold up on 5s ,is because for a mod1 it is like $50 to Australia,since postage is like $38.
Seeing that my packs are 5000mah with 20c rating,they will be ok for a 20t pinion right?Or will i need to get a lower tooth count pinion?
pinkpanda3310
09.26.2009, 07:30 AM
I expect they are the same pinions as used in a flux ( with rebadged mamba system ), but don't quote me on that.
http://www.scriptasylum.com/rc_speed/_top_speed.html This should help with what gearing to choose.
scarletboa
scarletboa's Avatar
09.26.2009, 12:53 PM
those pinions like to wear out when used with steel spur gears. as long as you stick with plastic spurs, that pinion will be just fine.
naynay12
09.27.2009, 06:25 AM
Ok well tell you the truth i need to buy a new spur as my 47t ahrdened one is stripped.(dont ask me how).So i guess i will order a 47t plastic.
scarletboa
scarletboa's Avatar
09.27.2009, 05:21 PM
you really don't need a steel spur gear. mod1 gearing is very durable and plastic will not wear out pinion gears. it will also be quieter when running.
