hi guys,quick question,want to run 4s/5s on my flm max w/mmm what would be a good starting point for spur/pinion truck already has all upgrades,and getting rid of my hv novak.looking at hyperion g3s.would there be any other batts. in their league.i mostly bash in street/parking lots.thanks
"looking at hyperion g3s.would there be any other batts. in their league"
Yes, but the Hyperions seem to be the #1 bang-for-buck at the moment, the only issue you may have is they will do serious damage to lesser drivetrains. You can't go wrong with Hyperion, they really deliver!
For balance on the maxx 2 packs are preferable. You can run a pair of 2s packs for 4s, or a 2s and a 3s for 5s total. Best to keep the same packs together, as all of the cells will age at the same rate if always run together. I would go with 5s, 4s setups tend to have high current draws, and 5s will allow for lower gearing (for the same speed if using the same motor) and you will get longer runtime.
