Is this a good emaxx braking system design
Superemaxx89
Is this a good emaxx braking system design - 02.19.2006, 04:45 PM
Made from t-6 6061 aluminum and weighing in at only 68 grams (.151 lbs), this e maxx braking system should work with little or no modification to your chassis. I don't actually have it yet, but I would like to hear your opinion on the design. I primarly made it to fit stock emaxx chassis, Ue chassis and torpedo/racebomb chassis. I'll probably find a way w/ the gorillamaxx as well. It is 2 inches long, and 1.375 inches tall. It compatible with the tmaxx braking system (braking post, braking nut). Only modifications needed for a stock emaxx chassis is to install a hex on the center drive cup. For the torpedo/racebomb chassis, there are 4 threaded holes for M6 screws (to provide very secure fit) that you will have to drill out of the lexan. It still a prototype, but it looks good so far. And you will have to program your esc to be foward only.
The purpose for this device is to eliminate a major percentage of stress on the esc. BK states (i couldn't find the post) that when the motor is put into reverse/brakes, it puts a ton more stress on the motor. If some one can find the post on this (where someone quoted what BK said) that would help alot. Thanks!
Just so you know what you are looking at, the 4 holes on top are the m6 screw holes. The center hole is for the tmaxx brake post. On the other view, the center hole is for the braking nut, the two shapes surrounding the hole are for weight savings, and the two small holes at the corners are m3 holes for the pressure pad mount.
maxxdude1234
maxxdude1234's Avatar
02.19.2006, 05:19 PM
Looks very interesting. Although I'm still a little confused as to how it works. Does it work with the gorillamaxx single speed conversion, and go where the second half of the tranny was?
Superemaxx89
02.19.2006, 05:39 PM
it works ideally with the gorilla single speed b/c the shifting servo is to be turned into the braking servo. But no, it goes where the reciever is (in stock emaxxes)
It will all become clear once I actually create the mechanism.
Serum
Serum's Avatar
02.19.2006, 05:43 PM
It could be a post from me, I keep preaching the very same thing.
I really have got NO idea how this thing works though..
where is it mounted on? You did a nice job on the drawing, but in my opinion it could be done a bit easier?
mmdooley
mmdooley's Avatar
02.19.2006, 05:47 PM
Same here , I don't understand how it will work on a e-maxx???
Superemaxx89
02.19.2006, 06:06 PM
It mounts through the 4 M6 threaded holes when using
If i still own a gorilla, i would be able to make mounting patterns for it, but I don't own one anymore.
Do you guys know how the tmaxx braking system works? It's a little hard to explain w/o demontration. but i'll try and take a stab at it:
this goes through the center hole on the top side (top side is illustrated in the 2nd and 3rd pic). The extension of the hole covers the majority of this part for added support.
The device will use an extended version of This gold nut. The gold nut will be inserted into the large middle hole of the 1st picture
A hex like this will be placed over your cvd cup (i use the supermaxx one), then this will be place over the hex.
The two brake pads shown here will be screwed into the two m3 holes shown in the first picture
When this spins (from the servo), the gold nut inThis picture gets pushed out. Applying force to the brake pads, which cramp the brake disc and slow the car down.
It will all come together once I buy it. The thing about buying these custom parts is that it costs $135 for one, but then to add on another one it is only $10...so i will probably order 5 and see if anyone wants them.
maxxdude1234
02.19.2006, 06:15 PM
I think I see where you're comming from. It sounds quite interesting.
Nick
COOKIES!
Nick's Avatar
02.19.2006, 06:17 PM
I still don't understand. How is it controlled, by another servo?
~ Nick.
Superemaxx89
02.19.2006, 06:22 PM
There is no more shifting servo, the servo gets Y-harnessed with the esc into the throttle input of the rx. That makes the servo move back and forth when you hit the brakes/throttle. When the servo spins, the brakes activate.
Superemaxx89
02.19.2006, 11:11 PM
this picture should illustrate my point:
macfjej
macfjej's Avatar
02.19.2006, 11:27 PM
will this require one of those highly expensive transmitters? the ones that can blend channels so pushing forward on the trigger operates a servo instead of the esc? or will the servo somhow be operated by the esc and/or reciever?
squeeforever
squeeforever's Avatar
02.20.2006, 12:09 AM
it wouldnt require one.
Superemaxx89
02.20.2006, 12:33 AM
corretomundo.
This is compatable w/ any radio system.
You just need a Y-harness to connect you servo to the esc...then you plug the y-harness into into the throttle channel...thats it. The only thing you lose is the shifting servo, unless you get creative.
Sneeck
RC-Monster Custom
Sneeck's Avatar
02.20.2006, 01:53 AM
And you'll loose reverse. I've been thinking with the idea myself, but still want reverse. All I can think of is set the break's on the 3rd channel, but that would suck. Can't react fast enough to engage the break's on the radio.
It is a nice idea.
Superemaxx89
02.20.2006, 02:27 AM
True, but if you want to save your esc, you'll have to lose reverse...no matter what tactic you use. According to that quote BK stated, reversing motor direction while still in the foward motion is one of the most stresful things you can do. And though it won't actually kill the esc, it will bring the esc one step closer to it.
I find I don't use reverse that much anyway.
The only alternate option I can think of would to be to use a tmaxx trans. That would work, but the tmaxx trans is far too weak for the torque of electric. And the only way to elimnate that problem is to buy a kit strong enough for electric... a foward only kit...:035:
