Here we go,
I needed a new project, and I wanted to have a truggy for a long time. I'm on a budget, so I got myself a "ansmann Hogzilla" chassis w/out wheels, motor etc., almost new.
They sell it as a "monster-truck", but that's fine for me...
I am curious about the quality. The diffs seem to be very solid, they're packed in a case, and sit between two mounts. I have cleaned and "shimmed" the diffs. the way they designed the diff seems solid to me, but on the other hand, it's more work to change oil in the differentials.
The quality of the aluminium-chassis is pretty poor, and the original rear diff-stabilizer-bar was already bent. I replaced it by carbon, and installed a stiffening bar to prevent the chassis from getting bent. The bar is hollow and is made of titanium and used to be in my broken right leg (marrow nail)... but who cares, it's titanium, and it's a very simple solution. and - funny thing - I just had to cut off a bit, and fits just perfectly, it weights 83 grams, but is much more rugged then any average aluminium.
http://s8.directupload.net/images/091030/temp/9lyjkuf8.jpg[/IMG]
I worked a bit on the steering-plate to get more steering. To get the COG centered as low as possible, I have placed the esc right behind the steering servo. Above the servo I will place the receiver. The motor sits right in the air-flow of the fan (I made a "tunnel"). Motor-mount and Torsen-Diff are taken from my Hobao Hyper 7-Conversion.
The position of the center-Diff is already a bit towards the right side, which is ideal.
The battery-mount has to be flexible, as my lipo-packs have different measurements. I like it simple and stable, and like that I can move the battey forward or backward.
The shocks needed some work, they're loosing oil, and the plate inside were loose. Further I increased the shock-travel. Total weight will be around 4,4 kg.
Next thing will be the shock-mounts, I will replace the weak aluminium-towers with some self-made ones (carbon).
The motor is a Losi xcelorin 1700 kv, which got cleaned, and bearings got replaced by some ceramic bearings. I sealed the magnet-bonding (kevlar) again with some super-glue.
The first runs with new 5s-turnigy-batteries have been great. The torsen is ideal for the longer chassis of the truggy; in the hyper 7, I had sometimes problems with wheelies when the torsen locked. this can happen here as well, but is more difficult to provoke. after the first runs I have to work on the steering, wich is too "soft" in the beginning and too "aggressive" in the end.
florian
