Budget Ofna Hyper 10 SC build from Hyper Mini STe
MetalMan
MetalMan's Avatar
Budget Ofna Hyper 10 SC build from Hyper Mini STe - 11.22.2009, 08:15 PM
It's been a while since my Mini Hyper STe has seen any action so I figured this would be a good opportunity to create a decent 4x4 short course truck! Many probably remember my Pro-4 build with a solid rear axle and independent front suspension (still need to post up pics of the latest chassis revision...), but this time I want something that will handle "properly".
If I truly wanted to turn my STe into a full-on 10 SC it would cost at least as much as the 10 SC truck itself. So here's the plan:
-custom chassis, with similar dimensions to the Hyper 10 SC's chassis
-Slash nerf bars on custom mounts
-reuse all components off the Mini STe's chassis except for the center-rear driveshaft
-Proline Slash rear 2.2 beadlocks (already acquired a few weeks ago)
-Proline Hardcore body (also acquired previously)
-cut apart center-rear driveshaft from Mini STe and use tubing to make one of the proper length for the 10 SC
What is on the way:
-Ofna 21121 front shock tower
-Ofna 21122 rear shock tower
-Ofna 21124 body post set
-Ofna 21125 front bumper set
-Ofna 21126 rear bumper set
-2 sets of Ofna Mutilator front shocks
So for a bit over $100 plus a few custom pieces you too could have a pretty cool Hyper 10 SC! However, it's still lacking the proper nerf bars, driveshafts, roll bar, and chassis braces but it should still work well enough
stum
11.23.2009, 08:33 PM
What is on the way:
I hate to say this, but by the time you figure out tires/wheels/body and the other goodies it's so not worth the effort. Keep the parts you have breakage.. and get the new unit.. prices will drop 20-40 bucks pretty quick.. or just use a coupon at amain.
MetalMan
MetalMan's Avatar
11.24.2009, 12:17 AM
The parts have already shipped and will be here tomorrow or Wednesday. Body/wheels/tires are already done. Not sure I want to spend the money on a new kit, I've got other priorities where that money can go (1:1 car). Only doing this since I have a Hyper Mini ST that's been collecting dust.
muck
muck's Avatar
11.24.2009, 11:25 PM
looking forward to some pics of your project.
Sometimes money does not matter when one gets an idea in their head...
