Warrior 9920 messed up?
Jasper
Warrior 9920 messed up? - 03.01.2006, 10:23 AM
I drove my 1/8 buggy today on a skate park. The ground was wet but there were no deep areas of water (plassen in Dutch) But after 5minutes driving the esc was acting weird. When I hit the throttle you hear a very weird beep and the pinion is moving: left-right-left-right etc. and very fast. The motor and esc were the whole time hand-warm. I drove back to home and made a video of it with pinion mounted and without.
With pinion: http://www.rcpics.net/view_single.php?medid=74207
Without pinion: http://www.rcpics.net/view_single.php?medid=74208
Setup:
- Warrior 9920
- Feigao 7XL
- 46 spur
- 14 pinion
- 16 GP3300
Sylvester
Sylvester's Avatar
03.01.2006, 10:40 AM
It looks like a radio problem, what radio are you using?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Sneeck
RC-Monster Custom
Sneeck's Avatar
03.01.2006, 12:28 PM
That's scary. See if any wire's are makeing contact with any metal object(such as antenna, receiver wire's), check if the cristall's aren't damaged/ fully in their socket's.
Did you change any throttle/ brake setting's on your radio that day?
Jasper
03.01.2006, 03:04 PM
I disconnected the motor and made everything dry. Then I tried it again. And the weird noise and left-right problem was gone! So I drove the battery empty in the street in front of my house. So the problem is solved. I think the receiver or wires were getting to wet and made some interfence.
Thank god :)
Thank you for your comments!
maxxdude1234
maxxdude1234's Avatar
03.01.2006, 03:23 PM
Water + electronics DO NOT mix. I never run my truck even if the ground is just damp, I don't think it's worth taking the risk. Good to hear everythings back working though Jasper
coolhandcountry
coolhandcountry's Avatar
03.01.2006, 07:50 PM
Well it didn't mess up totally. I glad it won't permanent.
Peace!
Country
Help support the
Rc-Monster
Buy here
crazyjr
crazyjr's Avatar
03.01.2006, 08:48 PM
I usually don't run my trucks for 2 days after it rains
ttrmike
got truck
ttrmike's Avatar
03.01.2006, 09:23 PM
Wow, I drive trucks in the rain. Haven't had a problem yet (knock on wood) .
