how to mount sprong
makana59
makana59's Avatar
Exclamation how to mount sprong - 03.02.2006, 11:53 PM
Hey guys,
I was just wondering how do you mount the sprong with the ofna gear? I tried to mount it as tight as possible but when I go in reverse the piece that holds the sprong on loosens and unscrews. I even tried putting the plate that screws the sprong on then putting a bolt after to hold the plate and still loosens. How do you guys mouint it? Thanks guys for the help. Grant
coolhandcountry
coolhandcountry's Avatar
03.03.2006, 11:35 AM
Do you have a pic of this? It sounds like your are missing something. Do you have the plates on the strobe.
Peace!
Country
Help support the
Rc-Monster
Buy here
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.03.2006, 11:40 AM
The lock nut is supposed to tighten against the aluminum "nut" that adjusts the slipper tension. This will keep the setting intact. Just make sure the nylon nut has some nylon left!
markland556
markland556's Avatar
03.05.2006, 02:10 AM
Im having a problem with mine too. The gear wont sit on the shaft strait no matter how hard i tighten it. It just seems to want to sit slanted, but the gear is tight. Any ideas??
  Send a message via AIM to markland556
Serum
Serum's Avatar
03.05.2006, 04:11 AM
You do use the stock slipper plates makana?
