UltraMaxx gear lube???
rcjmaxx
UltraMaxx gear lube??? - 03.05.2006, 07:01 PM
There seem to be some UltraMaxx tranny gears for sale on Ebay.I know some of have these in your Emaxxs.I remember an ad saying these gears needing a "special type of lube",is this so or can you use the same lube that you use in the stock transmission? Thanks
HotnCold
HotnCold's Avatar
03.05.2006, 07:15 PM
I have that tranny and it is a special type of lube - have no idea what it is though - opened it up saw it and thats about it -
Hows that "Hope and Change" working out for Ya???
coolhandcountry
coolhandcountry's Avatar
03.05.2006, 07:40 PM
It would seem to need some stick stuff. If it is on the housing of trans it is not lubing. I don't know what it is.
Peace!
Country
Help support the
Rc-Monster
Buy here
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
03.05.2006, 08:03 PM
I'm not sure what kinda lube it is, but I can email Microwebtech(aka..Dan) and ask him and I'll let you guys know....I'll send it now.....
Papa
Papa's Avatar
03.05.2006, 08:04 PM
I used associated black greasehttp://www2.towerhobbies.com/cgi-bin...2&I=LX2880&P=K
sjcrss
sjcrss's Avatar
03.05.2006, 08:21 PM
Just a FYI for anyone looking at the gears...they are Gen II gears....where as the Gen III gears have steel pins inserted into the gears so the shift dog will have a steel to steel contact. just some usefull info to everyone.
sjcrss
sjcrss's Avatar
03.05.2006, 08:36 PM
I emailed Dan, and this is straight from the site...i hope this helps.
Description of this grease:
Industrial Moly EP grease.
Lithium 12 hydroxy extreme pressure grease.
Contains molybdenum disulfide for protection against wear.
Contains polyethylene for superior film strength.
Resists change in structure and consistency.
Anti-wear, anti-rust, and anti-oxidant.
Temperature range:0° – 290° F
NLGI No.2
Dropping point 350° F.
WARNING: Contains petroleum hydrocarbon lubricant, organic zinc
compound and molybdenum disulfide. May cause eye or skin irritation.
Wash skin with soap and water.
Flush eyes with water for at least 15 minutes.
If film or irritation persists, seek medical attention.
May be harmful if inhaled or ingested.
Use only with adequate ventilation.
If ingested, do not induce vomiting.
Contact a physician immediately.
KEEP OUT OF REACH OF CHILDREN.
Gustav
Gustav's Avatar
03.05.2006, 08:51 PM
The stuff that comes with the ultramaxx gears seems a lot like associated black grease to me,aint nothing special about it.Just use a good quality grease,whatever you normally use in the transmission and on diff ring and pinion.I use Finish Line premium synthetic stuff from a bike shop.
rcjmaxx
03.06.2006, 05:52 AM
Thanks for all the input.Anymore is welcome.
