i just bought a mod1 14T pinion for my converted hyper 8, but theres a terrible grinding sound between the pinion and the center diff, and theres a lot of friction. They are both mod1, so shouldnt they mesh? i've set the mesh correctly and there is a fair bit of play in between the gears. I dont know what else to do?
there should be very little play between the gears. thats where the sound is most likely coming from.. i mesh my gears by hand. But there should be a very tiny amount of actual play between the gears- just enough to make a small "tink" noise between the gears.
i tried different positions ranging from a lot of play to none at all, and it still grinds really badly no matter the position. is it possible the spur is like mod0.9, or mod 1.1 or something?
no- i have run this setup..
check motor bearings, check diff bearings
Bizzare. Only thing I can suggest really is to remove the pinion, and run it around the outside of the spur with your finger- if it jumps teeth and doesnt stay in constant mesh tehn its not the same pitch as the spur...
it seems to fit just fine when i roll it round with my finger.
its really weird lol
i should hav just bought the damn vorza instead of attempting to convert a buggy
Hard to tell the shape of the tooth from the pic, but see the pic below. The one on the right is meant for plastic spurs only and roll very rough on steel spurs. The one on the left is meant for any spur, metal included. It's about the shape of the tooth. Not sure if this what you're talking about, but something to look at. Maybe a pic or a movie so we can hear how is sounds would help.
the gear on the left is a clutchbell, can you get pinion gears like that? is there something special that they are called or is the only way of telling by looking at the pic?
