What 6s battery for 1550 kv ?
Gallagher
What 6s battery for 1550 kv ? - 12.31.2009, 09:03 AM
I used to have Neu 4S 25C 5000mah lipo for Neu 2200kv motor.
Now I switched to Tekin 1550kv motor but I am not sure what rating will be suffice.
Will Hyperion 6s 35c 3300mah be enough or any better suggestions?
Thank you.
TexasSP
Something, anything, nothing
TexasSP's Avatar
12.31.2009, 11:20 AM
No reason it shouldn't work unless that motor pulls over 115 amps constant.
www.cubicle101.com
12.31.2009, 12:52 PM
Depends what runtime you want...
jsr
01.01.2010, 03:17 AM
Theoretically, if you gear it for the same speed, you should need less current rating with a higher voltage setup. Sounds like you'll be fine unless you're gearing for insane speed runs.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.01.2010, 08:31 PM
I have that exact battery powering the tekin 1900 kv motor which draws 2/3 to 3/4 the current as my 2650 on 4s (eagletree tested). I couldn't be happier about the performance and temps of the setup.
Area 52 Ranch Raceway
T.R.C.R.
Gallagher
01.02.2010, 11:41 PM
Thank you all guys. I use exactly the same gearing as my 4s setup.
I want the batteries feel comfortable with the setup.
I was think about 4200mah but it is heavier than 3300mah.
In addition to all your advice, I think 3300mah should be OK.
