Does anyone run Flex Chassis braces?
brushlessboy16
brushlessboy16's Avatar
Does anyone run Flex Chassis braces? - 12.31.2009, 12:00 PM
Like the spring flex unit from Fioroni?
Replaces the solid rear chassis brace with what basically looks like another shock absorber.
Anyone run them? If so how do they perform?
Nard Cox
n00b
12.31.2009, 12:21 PM
This thing (I assume)
Source
brushlessboy16
12.31.2009, 12:26 PM
yes.
12.31.2009, 12:55 PM
RyuJames wrote extensively about that exact brace in one of his homemade carbon fiber chassised race machines.
>>>>>>>>>>>search<<<<<<<<<<<<<<<<
Hmm, seems a bit gimmicky...
I have heard that some people prefer to run the plastic rear chassis braces since they flex more and allow the chassis to absorb some of the force from the suspension. I guess this is the next level? It will have to be made very well, and gas charged...
Semi Pro
Semi Pro's Avatar
12.31.2009, 11:08 PM
i have one and i dont like it
it could be because of my carbon fiber chassis, it could be because i am just more used to the way the buggy was before
i can tell you it had alot more flex in the rear when useing it but again it may be diffrent with an aluminum chassis
rootar
rootar's Avatar
01.01.2010, 12:50 AM
more of a gimmick than anything else.
Ryu James
Ryu James's Avatar
01.06.2010, 03:20 AM
its not a gimmick, brushlessboy. i have used them on all my rides and noticed a big difference. in fact, the difference was too much so i used 8mm washers to dial in the amount of flex. by placing washers over shaft where the spring sits it acts like a spring retainer nut on your shocks. the more washers you use the less flex you get. anyway, i was able to dial in the right amount of flex for my track and saw noticeable gains in handling. it just felt much more supple all around. friends who drove my cars commented on that they noticed it too. check my threads on my RC8t and Losi 8b 2.0 and you will see how i used them with the washers.
Jammin SCRT10 Neu 1512 1y
