Hyper 7 brushless conversion
Bazzokajoe
Talking Hyper 7 brushless conversion - 01.04.2010, 03:04 PM
Hey guys, first post so be nice :)
Just bought a hyper 7 and sold off all my nitro junk, modded the radio tray and now i have a little project on my hands
firstly, anyone on here have a converted hyper that they could link me to? i'm a little confused as to what body to use, as the stock one is all chopped up from factory, i have filled in the holes but ideally i would like a more streamlined one...
I've ordered the caster racing battery boxes, caster racing esc mount and a RCM motor mount, i intend on setting it up in a similar configuration to the caster racing fusion, with the motor in the place of the fuel tank, i will have to cut the chassis under the spur gear to make it fit, but it should offer better balance.
this position limits me to motors of around 73mm or less, is that a problem?
i intend on getting a xerun ESC and at the moment i'm not really sure what motor to get...
I was looking at the tekin motor http://www.rc-monster.com/proddetail...t8motor&cat=20 and thinking that the 2050kv one teamed with 6s lipos... but i'm not really sure...
i could just go with the xerun combo, that comes with a 2000kv motor... i really dont know...
i will be getting 2 5800mah 3s (or possibly 2s to keep the weight down, but i dont particularly care... recommendations?) 30c zippy flightmax lipos so i should be ok in the amps department...
i will be mainly bashing and doing speed runs but i would also like to race infrequently. so i would like something that will run cool and long.
thanks guys!
jasje
01.04.2010, 04:04 PM
2050kv on 6s will give you insane speed and is overkill. 4s on 2050kv will keep your temps and weight down.
D8 Driver
01.04.2010, 04:19 PM
i agree, 4s is more controllable.
Bazzokajoe
01.06.2010, 05:02 AM
Thanks for the help so far,
i will probably be getting 2 2s and 2 3s still... as i will want to run 4s, 5s and 6s at various times... would it be safe to run those motors on 6s? as it is over 40000rpm?
does anyone have any experiance with the xerun 150a yet?
Bazzokajoe
02.02.2010, 03:14 PM
so... i got my mmm combo today :D cant wait to run it...
first question's..
what pinion should i use? its the 2650kv combo
the setup weighs around 4kgs....
my batterys are 5200mah 30c 7.4v
any recomendations? thanks guys :)
02.02.2010, 11:58 PM
http://www.scriptasylum.com/rc_speed/_top_speed.html
Without knowing the diff ratio, spur gear size or tire diameter its hard to say, but 48/14 = ~38mph on 4s lipo with typical 1/8 buggy info inputted. I would check out the 1/8 buggy section for similar setups & info :)
