I'm curios abouth amp!
alport
Exclamation I'm curios abouth amp! - 01.07.2010, 07:14 AM
HI
Give the same lipo same amperage at different capacities?
For example. After a while of using my lipo (5000mah 20C) it's capacity drop to 4000mah. Can that lipo still give 100A or it's drop to 80A too?
nativepaul
nativepaul's Avatar
01.07.2010, 09:26 AM
It is 80, the "C" rating is what multiple of the packs capacity it is safe to discharge a pack at so a 4000mAh = 4Ah 20C pack is good for 4x20=80Amps
if you need a 100Amp capable pack but only want the weight/size of a 4000mAh you need to move up to a 25C pack as 4000mAh = 4Ah, 4Ahx25C=100A
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
alport
01.07.2010, 11:21 AM
I know how to calculate current but I want to know if a 5000mah 20c lipo keep giving 100amp current when it's capacity drop to 4000mah.
big greg
01.07.2010, 11:51 AM
most likely not, apparently the cells are beginning to weakin, so i would say they might not even put out a full 80 amps as of now
