Radio help
rchippie
rchippie's Avatar
Radio help - 01.14.2010, 12:37 PM
I have a ? for those using mechanical brakes with a M8 radio . Are you guys using the auxillary 3rd channel or the esc channel on a y cable ?. If you guys are using the auxillary channel how are you adjusting the EPA ?.
REAL MEN RUN BRUSHLESS
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
01.14.2010, 12:52 PM
im not using that setup but i would assume that you would use a y splitter.. using the third channel would require you mix in the channel with the esc... not hard but a pain in the ass
rchippie
rchippie's Avatar
01.14.2010, 12:53 PM
I was thinking the same thing, but i wanted to make sure . I dont think the (auxillary) or 3rd channel on the m8 is a true thrid channel . You have to manually adjust the action of that channel from what i understand . . I dont belive you can adjust the EPA & the other adjustments on that channel .
maxair45
maxair45's Avatar
01.14.2010, 02:01 PM
I was never able to get the epa or anything working for the third channel also....I had it for 2-3 years, its possible I am just clumsy though.....
