holes in tires vs rims.
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
holes in tires vs rims. - 01.28.2010, 03:40 PM
well im about to get my new badlands mounted on my rpm revolver rims.. is drilling holes even necessary? i do alot of mud runs and it sees alot of beach time so im worried about it all collecting inside my tire...
glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.28.2010, 03:44 PM
If you are playing in mud, bashing with badlands... no need to put holes in anything in this case. Seal them up real good to keep the water and mud out. If you ever have an issue with the tires being too bouncy or staying flat/expanded due to heat build up or cent. forces, etc... THEN you can put holes in them.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.28.2010, 05:16 PM
If there are already holes in the rims then holes in the tires will be necessary, otherwise the water that gets in will have no where to go.
jhautz
jhautz's Avatar
01.28.2010, 07:12 PM
Yea. Holes in the tires, but not the rims woiuld be the way to go IMO. If anything gets in, it will get thrown out while you are running.
to make it...
or break it...
Silent...But Deadly
wallot
wallot's Avatar
01.28.2010, 07:14 PM
Tires. never rims.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
 Send a message via ICQ to wallot
dkexige
01.28.2010, 10:59 PM
I must be ignorant. I've always put holes in the rims, and then getting annoyed at all the sand and dirt that gets trapped inside. How do holes in the tires affect their durability? Where do you punch them? Somewhere along the treads?
.dk
jokerjustin
01.28.2010, 11:29 PM
i read up a little about it and most ppl punch a small hole in the center of the tread.. i just dont feel to comfortable doing it as i am in mud puddles quite frequently.
jhautz
jhautz's Avatar
01.28.2010, 11:43 PM
http://www3.towerhobbies.com/cgi-bin...?&I=LXXVG5&P=7
handy tool for punching tire holes. Some people just use a leather hole punch. That works too. Just put 2-3 equally spaces holes along the centerline of the tire. Any water, mud, sand, etc that gets in the tire will just get flung out while the tire spins.
to make it...
or break it...
Silent...But Deadly
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.29.2010, 12:32 AM
I use a drill bit in my dremel and put two holes oposite each other in the center of the tire. Works great, esspecially when getting wet, next run the truck shakes for the first 30 seconds or so but then the foams are wrong out and truck drives great.
glassdoctor
TEAM FUSION
01.29.2010, 12:37 AM
Back in the day, most racers put holes in the wheels. Now I think most do holes in the tires... as mentioned, this allows water to get out and lets in less dirt than a hole in the wheel. I use body scissors to notch a small hole in the center of the tread... small leather punch would be cool though, as long as you remember to do it before gluing. :)
But if you are running in mud, etc and not racing... you shouldn't need any holes.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
