RCM motor mount X1CRT
Doug Shelp
RCM motor mount X1CRT - 01.31.2010, 02:39 AM
the center diff on my rcm x1crt seems to have alot of fore and aft movement.I did put three diff shims under the front bearing but it didnt seem to help. I have a rather anoying on and off trottle click/clack. the diffs are fresh rebuilbs,the gear lash/mesh seems good.the hole diff moves fore and aft about 1/16 with the three shims installed on the one end.any idea's?
riverat1540
riverat1540's Avatar
01.31.2010, 02:39 PM
mine did the same as well, had to add shims but the spur is thinner than the pinion so i just had it set so the spur was always 100% on the pinion when it moved, also had more even wear on the pinion this way.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
