Gear question to a new build E-Maxx
beaufort12
Gear question to a new build E-Maxx - 02.05.2010, 05:20 AM
Iīm building a new E-Maxx Brushless (MMM) with a lot of option parts.
At the moment Iīm not sure if I choose the right parts for the gear.
I use the Traxxas transmission, motor 17T/68T and would like to use the HB Diffs C8178 with the pinion C9009.
Do I have to change the motor gear or will it these parts fit?
The Maxx should not be a high speed racer, more a basher. I will use 4S lipos and 6S aswell.
Thanks for your comments
02.11.2010, 05:21 PM
No need to change the main spur/pinion gearing- using 1/8 buggy diffs lowers your overall gearing slightly, it has the same effect of using ~1 less tooth on the pinion or 2-3 teeth less on the spur, but the overall effect is minimal.
beaufort12
02.12.2010, 02:07 PM
Hi suicideneil,
thatīs not correct. I read a lot of it meanwhile. If you chosse the 43/10 ratio, a standard E-Maxx will run with 4 S batt a max. speed (calculated with R/C calculator) of 36,61 km/h. With a 43/13 it goes up to nearly 48 km/h.
The axle torque at 43/10 is 30% higher, than with the 43/13....so the gear with some tooth up and down as a great influence i think.
Overdriven
Destroyer of Tires
Overdriven's Avatar
02.12.2010, 09:59 PM
The standard emaxx uses a 37/13 diff ratio, and neil is correct. If you went with the standard buggy gearing of 43/13, it would be the same as using a 15T pinion with the stock emaxx diffs. Also, your axle torque does not depend on the diff ratio. It depends on the motor and the overall final drive ratio. I don't know what motor you're using or what you're speed goals are, but I'd recommend the 43/13 buggy ratio.
beaufort12
02.13.2010, 04:46 AM
Overdriven,
I use this one
http://www.scriptasylum.com/rc_speed/_gear_calc.html
and here the top speed estimator:
The upper is the standard E-Maxx andtop speed is 34mph, torque 10
The lower has a top speed 26mph, torque 13
changes in the second: from 37/13 to 43/13 and from 17T to 15T.
Donīt know from which experience you took your advice, but this says itīs different...
02.13.2010, 08:30 AM
You need to use a BIGGER pinion gear when using the 1/8 scale diffs, not a smaller one:
bigger pinion and/or smaller spur = gearing up
smaller pinion and/or bigger spur = gearing down.
Thats why your speed is greatly reduced when using the lst diffs in the example above, becuase lst diffs have a lower ratio than the emaxx ones- you introduced a 2-folder gear reduction
I happen to use 43/13 diffs in my GorillaMaxx with 70/24 gearing on 5s lipo for ~40mph topspeed; redo your sums with an 18-19t pinion & the lst diffs and you will find it comes out about the same as the standard emaxx example
Overdriven
Destroyer of Tires
Overdriven's Avatar
02.13.2010, 02:31 PM
I used 15t with 37/13 and 17t with 43/13 since that's what you said you wanted to run. With 37/13 + 15/68 you get 48km/h, 23.65:1 fdr (final drive ratio), and 11.36 axle torque. With 43/13 you get 47km/h, 24.25:1 fdr, and 11.65 axle torque. So my point about axle torque being dependant on fdr is correct, and changing to the 43/13 diff ratio requires changing the pinion by 2 teeth to maintain the same speed and axle torque. Although I think there is a language barrier thing or lack of explaination going on contributing to the confusion.
I say go with 43/13 over the 43/10 because of gearing options. With 43/10 you'd need 54/22 gearing and 6s to get to 45mph (70km/h). With 43/10 diffs and the 17/68 gearing you said you wanted to run, top speed was around 20mph. But maybe you're okay with that. Either way I hope our answers have helped in your descision making process.
beaufort12
02.14.2010, 05:52 AM
agreed thanks
at the moment I only have the C8178, which is 43/10 (I ordered some parts to build up a 43/13 ratio out of them). So until I got the parts (I hope they will fit) The HB C80841(43/13) is not available and I need some diffs which fit into FLM hybridīs.
I decide to go with 65T /22T, axle torque is at 11,19 and top speed at 4s nearly 51km/h.
With the standard 68T / 17T axle torque inceases to nearly 15 and I donīt know if thatīs too much, and itīs too slow
