I want to run an external BEC with my MMP and I just want to verify that I can disable the onboard BEC by removing the middle wire same as the MM? I am running a JR Z9100s servo which can pull a lot of volts and I hear it can put a strain on the onboard BEC causing momentary shutdowns.
