Motor for 4s LiPo
Tazz
Custom
Motor for 4s LiPo - 03.21.2006, 01:12 PM
Need a motor for E-Maxx that will run on 4s lipo. The E-Maxx is stock except for these upgrades: alum diffs and cups, steel cvds, steel center drive shafts and steel idler (single speed). This will be used for mostly bashing.
Serum
Serum's Avatar
03.21.2006, 01:14 PM
Sounds cool, a 10L would be nice.
It depends on the quality of the cells though. What is the speed you wish? about 30-35 mph?
Tazz
Custom
03.21.2006, 02:14 PM
30-35 mph sounds good. The lipos I am looking at useing are 2 2S packs for $76.50 ea.
4000mah Capacity
7.4 Volts
44mm X 132mm X 13mm
Rated at 48 Amp Constant Discharge(12C)
Rated at 64 Amp Burst for 10 seconds(16C)
175 grams
Just incase anyone is wondering , this is my mostly stock E-Maxx and not custom one that I am building in the other thread (yes I have 2).
Tazz
Custom
03.21.2006, 02:19 PM
Or I my go with these For $72 ea.
6000mah Capacity
7.4 Volts
45mm X 135mm X 24mm
Rated at 60 Amp Constant Discharge
Rated at 72 Amp Burst for 10 seconds
292 grams
So the 10L will work good on 14.8v ?
coolhandcountry
coolhandcountry's Avatar
03.21.2006, 06:00 PM
The 10 L should push your around pretty good with out tearing up to much to.
Peace!
Country
Help support the
Rc-Monster
Buy here
poconoblmaxx
poconoblmaxx's Avatar
03.21.2006, 06:35 PM
I've been running a 10L in my revo on 12 cells and its the perfect bashing setup. I get nice run times and fairly good speed and it runs cool. Should be perfect for 4s lipo.
squeeforever
squeeforever's Avatar
03.21.2006, 08:05 PM
i would personally go for the 7xl. it will run cooler and just be better over all. i would also go for the second packs. there cheaper, are capable of more amps, although there are slightly bigger, they will perform better.
Tazz
Custom
03.21.2006, 08:41 PM
Are the run times the same between the 10L and the 7XL?
squeeforever
03.21.2006, 09:09 PM
actually the 7xl will probably give better runtimes. what kind of speeds are you looking for. you might also want to think about the 8xl.
Serum
Serum's Avatar
03.22.2006, 01:20 AM
10L will get you a better runtime, 10L will be easier on your drivetrain and is more than enough for bashing. The 10L will be less hard on your lipo's too.
Superemaxx89
03.22.2006, 01:54 AM
a 7xl vs. 10l, wouldn't the 7xl draw wayy more amps than the 10L? Hence worse runtimes?
Tazz
Custom
03.22.2006, 07:55 AM
I just checked and it shows that Mike is out of stock on the L motors. I wanted to place an order this week is there a Lehner motor that is comparable to the 10L? What gearing should I start with?
maxxdude1234
maxxdude1234's Avatar
03.22.2006, 01:29 PM
Definately go for the 6000mah lipos, and whether you chose the 10L or 7XL (personally I would go for the 7XL) run times will be 25-30 minutes plus
coolhandcountry
03.22.2006, 04:05 PM
I couldn't get that much runtime out of my 7xl. I ran gp 3700 and got about 10mins. It was a fast 10 min.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
03.22.2006, 04:08 PM
When the batteries stayed in place i managed a good 15 minutes on 14 cells with the 7XL
