XTM Mammoth ST
fastlane01
XTM Mammoth ST - 03.07.2010, 08:48 PM
I am going to be converting a Pro Chassis to brushless. I need a mount. Where can I get one.
simplechamp
simplechamp's Avatar
03.07.2010, 08:55 PM
I would think with all the different mounts Mike makes you could find one to work right here at RCM. Measure your spacing for the two screws that attach the center diff mounts to the chassis and email Mike to see if he has any that match.
MetalMan
MetalMan's Avatar
03.07.2010, 09:46 PM
The only way an existing mount (not made for XTM) will work is if fastlane01 also gets the center bulkhead made for the same vehicle the mount is. XTM 1/8 uses center bulkheads with an offset center bearing hole.
fastlane01
03.07.2010, 09:51 PM
Thanks MetalMan. I will try to get Mike to make me one. If not an L bracket and some Drilling will have to do.
fastlane01
03.08.2010, 03:43 PM
Well I ended up with a X Terminator SC converted. I will be going brush less. 2650kv MMM out of my traded DM-1 spec
