Go Back   RC-Monster Forums > Support Forums > Team Tekin
so guess ill be calling tekin
ikpthegame
so guess ill be calling tekin - 03.22.2010, 02:04 AM
so i already told ya about the bent shaft, but now ive got a esc problem as well. it only seems to happen when im on it hard, it likes to just shut down. when it does this the VC light blinks and the motor beeps, and i still have steering. sometimes it will restart it self and work till im on it hard again. and when it doesnt restart i have to resink the radio to the esc to get it to work again. and yes i have tried 2 different radios. this is the first time ive used it since i got it back from tekin, so ive got good luck.
fastbaja5b
fastbaja5b's Avatar
03.23.2010, 12:40 AM
What battery are you using? Sounds like under hard acceleration the battery is dropping voltage under load and triggering the LVC
Say Less, Do More.
ikpthegame
03.23.2010, 02:05 AM
its not lvc, lvc would have more that one light on. i forgot witch lights light up when you hit voltage cut, but its not just #7.
