Took a peek inside my flux tranny
josh9mille
josh9mille's Avatar
Took a peek inside my flux tranny - 03.22.2010, 02:36 PM
I had some of the truck appart putting in the BP diffs and thought i would look inside the tranny to see the warn idler gear everyone talks about. Well i didnt see and wear on idler gear at all, but i did see quite a bit of wear on the top gear. It actually looks quite bad, and with only having maybe 8 packs run through it it kind of has me worried. Is there an upgrade for this? Ill probably pick up the TCS idler and drive gear anyway since they are only 6 bucks. Does someone make a beefed up top gear as well?
JThiessen
JThiessen's Avatar
03.22.2010, 03:07 PM
Not that I'm aware of. I'd just buy another gear and loosen up that slipper just a hair.
03.22.2010, 03:19 PM
Good synthetic grease, or alot of people seal the lower case with some silicone and run some gear oil, or oil stabilizer. Just enough to have the lowest teeth submerged on the bottom gear, when they spin it will coat the gears evenly and not cause too much drag. Friction causes wear and some sort of lubricant will help cut down on the friction.
rtoc
03.22.2010, 04:24 PM
Are we supposed to put grease in the Flux's center tranny? I converted a tranny from nitro with the Flux idler gear and I've been running it dry. Would lithium car grease work?
swiftneed
swiftneed's Avatar
03.22.2010, 05:29 PM
Hey Linc what about that LUCAS oil would that be good or is the viscosity to thick
JThiessen
JThiessen's Avatar
03.22.2010, 05:43 PM
I've always used the light white grease in my "dry" items like trannies. Silicone based so it has good adhesion qualities, and doesn't break down.
03.22.2010, 06:02 PM
Thats the stuff, lucas or stp stabilizer. Sikeston34m has used that to good effect in his trannies... Lube up your tranny. Harold will have a feild day with that...
simplechamp
simplechamp's Avatar
03.22.2010, 09:51 PM
redshift swears by the STP oil treatment, and I use it in my E-Revo tranny and diffs with good results.
