Ayuda por favor con el modo fail safe spektrum/mmm
golfito
golfito's Avatar
Ayuda por favor con el modo fail safe spektrum/mmm - 03.24.2010, 01:26 PM
Consultation on fail safe mode on my radio spektrum dx3s and reverse function.
If I want him to set the fail safe way to slow down mmm I program the only direct and void the reverse?
Or you can use the direct and reverse while keeping the fail safe mode that when activated and not slow the car shot out in reverse?
Or I had to conform and to fail safe mode in neural?
03.24.2010, 01:41 PM
Use neutral for failsafe- you dont want the truck to carry on driving along, use neutral & it will roll to a stop instead.
golfito
golfito's Avatar
03.24.2010, 01:58 PM
Thank you!
So if the fail safe setup with the radio on I have to brake disable reverse mmm.
And if I want to use the function I have to reverse him to set the fail safe in neutral.
Sorry for my English is that I speak Spanish
SunnyHouTX
SunnyHouTX's Avatar
03.24.2010, 02:20 PM
If you disable reverse completely, you can have a little brake in the fail safe when you set it. If you don't, then it will stop first and immediately go into reverse.
golfito
golfito's Avatar
03.24.2010, 02:33 PM
Thanks for your answers!
