how to check if diff are still LSD or not ?
Page 1 of 2
Jason
how to check if diff are still LSD or not ? -
04.09.2010, 10:40 PM
I have doing a small mods to my stampede to put it LSD few months ago and now want to recheck if it is still LSD anyone know how ?
Jason
Find all posts by Jason
2
04.09.2010, 11:18 PM
OK This ones got me LSD?
Find all posts by Arct1k
3
skellyo
04.09.2010, 11:24 PM
I was guessing limited-slip diff? Otherwise, his Stampede needs to visit rehab.
skellyo
Find all posts by skellyo
4
Jason
04.11.2010, 05:32 PM
yes limited slip diff
Jason
5
simplechamp
04.11.2010, 08:00 PM
What mod did you do exactly and/or what about the mod makes it only temporary?
simplechamp
Find all posts by simplechamp
6
bryan
04.11.2010, 08:49 PM
WOW DUDE
bryan
Find all posts by bryan
7
nitrostarter
04.11.2010, 09:52 PM
Unless you glue the differential spider gears together, you will always have a "LSD"
To check for it, pick up the truck and spin the wheels...
N. Rustler conversion
nitrostarter
Find all posts by nitrostarter
8
Andrew32
04.12.2010, 10:40 AM
nitrostarter
arnt the mag transmissions open diff out of the box? you would have to seal and add oil or putty or peanut butter or jelly or ky
Andrew32
9
MikeW
04.12.2010, 12:11 PM
I use Ky for optimum performance out on the track
MikeW
Find all posts by MikeW
10
Bondonutz
Fat Kid Engineering
04.12.2010, 12:42 PM
MikeW
It's perfect for the tight corners !
Bondonutz
Find all posts by Bondonutz
11
nitrostarter
04.12.2010, 12:45 PM
Bondonutz
Helps the holeshot as well.
nitrostarter
12
MikeW
04.12.2010, 12:48 PM
Also gives you maximum control in the pit lane which can be a very tight fit.
MikeW
13
04.14.2010, 12:42 AM
this thread oozes "WIN"
Find all posts by _paralyzed_
14
Andrew32
04.14.2010, 12:47 AM
sounds life all you need for a PERFECT day the "tracks"
Andrew32
15
Jason
04.19.2010, 11:49 PM
ok.. let me explains some more
when I lift the truck in the air and turn one wheel by hand the other wheel dont move look like it need more pressure..
when I lift the truck in the air again and turn the spur by hand the both wheel turn in the same way..
when I lift the truck in the air and push some gas throttle the both wheel turn the same way even at low speed..
so my diff are LSD right ?
Jason
Page 1 of 2
Linear Mode
Switch to Threaded Mode
