Need help with ESC problem!
jsr
Need help with ESC problem! - 04.13.2010, 03:52 PM
I'll start off with my setup:
Kyosho DBX8e (a nitro DBX I converted to brushless and 1/8-scale)
- weighs just over 5lbs with battery
Hobbywing EZRun 60A ESC with external UBEC
Medusa 3300kV 3650 motor
3s LiPo
My buggy's been acting strange recently. My old 3s packs (3000mAh 30C) are getting old and I could feel them losing punch at my last track outing. So I picked up a couple of new Turnigy 5800mAh 25C 3s packs. When I tried them out this past weekend, the buggy accelerates hard (harder than with the old packs). As it ramps up in speed, it feels like it's pulling really hard. As it approaches top speed, it slows down a bit and tops out early. Using random speed numbers for example sake, here's what's happening...
- Accelerating at full throttle, it pulling hard (say at approx. 35mph at this point) and seems like it will pull to 40mph
- As it hits approx. 35mph, it slows to about 30mph and stays there
I tried both old and new packs and it does it with both. As I ran it more with the old packs, it would do it less often and sometimes hit full speed. As the packs ran lower in voltage, it started to run normal and hit full speed. Because the new packs hold voltage so much better, it would always cut-back and slow down. I checked wiring and nothing is cut or damaged.
If I slooowly roll into the throttle, I can get it to hit full speed (which is faster with the new packs than with the old). But if I get on the throttle just a tad faster, it will cut-back.
When it does this, both the ESC and motor are running hotter than normal, about 20-30F more on the ESC, only about 10F more oh the motor.
I checked the drivetrain for binding and all is smooth. I recalibrated the ESC and Radio. I confirmed (by holding the buggy) that the ESC is seeing full throttle (via an LED on the ESC that lights when I hit the max throttle point).
It seems like it's a voltage related problem with the ESC, but why and what? What would cause it to slow down due to higher voltage (or run to full throttle with lower voltage)?
Need help as this is driving me nuts and made me cancel my last trip to the track.
Thanks for the help.
04.13.2010, 04:30 PM
Only thing I can think of is that the escd is artificially limiting topspeed somehow- could be punch or rpm related, could be that its a 4 pole motor and needs some setting tweaked. Hard to say really- do you have the programmer box for it?
04.13.2010, 04:42 PM
It could be a timing thing - wondering if the ESC can cope with that many pulses at full voltage with a 4 pole motor...
Suspect at flat out that the timing is going up the wazzoo causing the motor to heat up...
Does it exhibit the same behavoir when not under load i.e. on the bench?
jsr
04.13.2010, 04:56 PM
I've run with this setup for a while now and it just started having this cutting-back problem this past weekend. I do have the program box for the ESC and can try changing the timing and punch to see if that will do anything. I haven't tested it on the bench. BL motors tend to overheat when not driving a load, so I don't want to risk that (especially with Medusa gone).
The ESC and motor have always run cool...max of 120F on either even on a relatively hot day (80F) on a big track. Don't know what changed.
Maybe something broke internally as the track is BIG jumps and I tried singling a big triple a couple of times this last track visit and didn't make it. I didn't tumble and crash, but I landed on all 4 wheels on the rise of the last jump. But the track has some big rough spots too so the suspension is pretty soft and I bottom on the big jumps, so maybe the impact finally made something give?
Any other ideas on what I can investigate? Thanks for the help.
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
04.13.2010, 05:03 PM
my esc kinda does something similiar after a huge jump. it seems to lose it's current settings and i have to go back and re-calibrate it.
after i got some 1/2 inch foam tape under it, it stopped doing it. it think the impact might have been jarring the unit into some kind of default.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
jsr
04.13.2010, 05:24 PM
I did recalibrate the ESC and Radio/RX together again, but that didn't help. My testing this weekend was just up and down my street to see how the new packs performed. that was when I noticed it was topping out early. I can try to go back into the ESC settings with the program card and set every parameter to make sure that at last the parameters are set and saved.
