Help looking for a certain pinion gear
simplechamp
simplechamp's Avatar
Help looking for a certain pinion gear - 04.25.2010, 06:34 AM
I am in need of a spiral/helical cut 13T input pinion that is 8mm diameter the length of the shaft, not reduced down. So far I can't find anything that meets all the requirements.
Anyone seen this available anywhere? Thanks!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.25.2010, 01:09 PM
I just spent 40minutes looking and found zip.
You might have to rethink your approach ?
lutach
lutach's Avatar
04.25.2010, 02:15 PM
https://sdp-si.com/eStore/
Select Metric, go down to gears, select Helical, Commercial & Precision and to the right you will see what they have.
