Sidewinder
George16
Supermaxx
George16's Avatar
Sidewinder - 05.02.2010, 08:28 AM
Does it have a built-in BEC or not? Thanks.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
05.02.2010, 08:31 AM
Yes but linear so will get hot on 3s
05.02.2010, 02:25 PM
My experience with the sidewinder in my crawler was not too hot. On 3s lipo trying to run a jr 9000t servo would cause the voltage to drop so much that the spectrum rx would switch off... So I upgraded to a ccbec and set it for 6.5v. Plenty of juice to the servo and rec, no more problems. On 2s the internal bec may be ok, but on 3s I would use an external bec.
George16
Supermaxx
George16's Avatar
05.02.2010, 03:50 PM
James, did you have to remove/cut the red wire?
Revo with OS .18TZ
05.02.2010, 06:04 PM
yes you do
George16
Supermaxx
George16's Avatar
05.02.2010, 08:13 PM
Thanks.
This is my first time to use a CC BEC so I'm not sure. I normally use Dimension Engineering's Sport BEC on my crawler and didn't have to remove the red wire.
Revo with OS .18TZ
05.02.2010, 08:24 PM
Thats probably as the ESC plugs into the BEC. All the BEC does is terminate the ESC's red wire and pass through the signal and black.
You have an option of direct wiring the BEC to the servo (using a y splitter) and leaving the red wire in on the esc. I do this on my crawlers to stop the RX having 4+ amps going through it...
To do this I use a revo servo splitter... Plug servo and BEC into Y - and plug Y into steering on RX - Just remove the red line on the Y section into the RX and optionally the signal on the BEC branch of the Y. This has the benefit of leaving all cables intact which is very helpful for software updates etc...
George16
Supermaxx
George16's Avatar
05.02.2010, 11:00 PM
Thanks Chris. That's basically what I did since I have an extra Y splitter. This is for my crawler, by the way.
Revo with OS .18TZ
05.02.2010, 11:14 PM
yes you do
Is your name James? NO. Mine is, and yes George I did remove the red wire to isolate the internal bec.
Damn mods, jumping in to answer questions...
05.03.2010, 06:51 AM
Actually it is my middle name...
