Originally Posted by jobo1
Hey guys,
I just received a used Tekin 2250 combo, but I got a couple of questions.
#1. Compared to the Castle 2200 motor, the Tekin motor turns like butter, it's so smooth. The Castle motor is MUCH harder to turn by hand, indicating that the CC motor has stronger magnets. Is this correct?
#2. The Tekin comes standard with 12awg wire, the MMM combo comes with 10awg. Does that mean the MMM combo can handle more current?
#3. Why is the Tekin system so much more expensive?
Thanks for any help given
I've been following this thread, wanting to know the answers to these questions myself.
I just purchased a Tekin 4038 2000kv version. I am VERY pleased with it. It can flip the E Revo backwards effortlessly, runs great, and will go into "crawler" mode with ZERO cogging.
Here's my attempt at answering your questions. My answers are incomplete, so I'm still collecting information.
This isn't a 100% sure indication of stronger magnets. Castle chose the 45SH strength, which is right up there toward the top of the scale. I've seen nothing to indicate what strength magnets Tekin chose to put into their motors. I do know they are pretty strong. I removed the rotor from my motor to have a look at that very thing.
Stator construction can and will alter the notchy feeling that you get when you turn the rotor.
No, it doesn't. Overall efficiency and the ability to shed heat is what determines a motor's power handling ability. Sizing, of course, plays a large role also.
The 10awg wire on the Castle Motor means it is likely to receive slighty more voltage since there will be less voltage drop before it reaches the motor.
The Castle Motor is well designed, but you can install any size leads on the Tekin, that you want. I put 10awg leads on my Tekin.
The addition of sensors means more parts. More parts equal more costs.
Castle is also VERY competitive when it comes to the market.
To answer these questions accurately, there needs to be a side by side comparison. Disassembled AND in performance that measures currents when being used on the same setups. Perhaps that would give us more accurate answers.
Nice thread and some very good questions. Thanks for posting.
