Hot Bodies D8T
bdebde
That's All Folks!
bdebde's Avatar
Hot Bodies D8T - 05.09.2010, 06:23 PM
I don't think I have seen one of these on here yet, so I thought I would post a few picks of mine. I used the Losi battery tray, and a home made motor mount. Power is 6s Neu 4100mah on a 1515/2.5D through a MMM. I know most guys here racing with a 2.5D are only using 5s, but I am only geared for about 38mph, and my truggy got TQ on it's first outing. I let another (much better) e-truggy driver try it out, and he wanted to know all my settings and all about my truggy. Sadly, the stock plastic servo arm let me down at the start of the main (notice new aluminum one in pic), so no win there.
ID:	8861   Click image for larger version
ID:	8862   Click image for larger version
bryan
bryan's Avatar
05.09.2010, 09:37 PM
Looks good.Sucks that the servo arm screwed up your day though.
sabongi
05.19.2010, 10:49 PM
can you talk about shaft/pinion clearance? You using the stock radio tray dremeled? Which pinion brand are you using and did you short motor shaft?
bdebde
That's All Folks!
bdebde's Avatar
05.19.2010, 10:58 PM
I am using a RCM pinion, and I put a thin spacer plate between the motor and mount to give enough clearance for the shaft. Clearance to the radio box is about 1 to 1.5mm, pretty darn close. The RCM conversion kit has a radio box that gives much more room for pinion clearance, I may get one in the future just to make motor/pinion changes easier.
Drifted Demon
06.10.2010, 02:33 AM
Im looking at one of these or the X2 CRT MMM 2200kv on 4s. Is this thing basher friendly?!
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
06.10.2010, 11:02 AM
That's a clean layout!
-Chad
PM ME IF YOU HAVE THE BELOW:
brushlessboy16
brushlessboy16's Avatar
06.10.2010, 11:23 AM
Clean!, how much runtime do you get with that pack?
bdebde
That's All Folks!
bdebde's Avatar
06.10.2010, 03:17 PM
Thanks guys. Yeah it should do fine as a basher, as most truggies will. Have not run the battery to lvc, but it does a 15min. main with a few warm up laps, no problem. I would say 20 min. runtime at least, judging by charge put back in after race.
