How far out of balance can a Lipo get befor I should worry ?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
How far out of balance can a Lipo get befor I should worry ? - 05.23.2010, 05:30 PM
I checked on one of my E-Revos today that I hadn't run in a month or so. I couldn't remember what state the Lipos were in since I used it last, anyway looks like I put it up with fully charged 2s packs (TrueRC 15C -20C burst)
I've had these packs for nearly 2 yrs and have served my very well so if they are on the way out I'm fine w/that.
One pack is even across the board and the other the #1 cell is 0.5 volts lower than #2. It stays this way regardless using the DUO3 to discharge or running them down via driving and when charging it falls 0.4-0.5 short still. The pack is still hard as a brick, no puffiness at all.
I never had a Lipo start to go like this, they usually start to swell or a cell just falls completely. Should I be prepared to chuck it or just run the dam thing till it starts to puff or not worry at all ?
EDIT, Now that I have a DOU3 I plan on doing the "storage" thing, Is 80% still the prefered percentage to doing this ?
sikeston34m
sikeston34m's Avatar
05.23.2010, 05:51 PM
Time for a balance charge. Or even a balancing discharge.
It seems like you should be able to make those cells come back in line with each other.
I would run it till it puffs.
I usually store my lipos at 3.8 volts per cell.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.23.2010, 06:53 PM
I've run it down to LVC and recharged, then balanced discharged and she still 0.5 below #2. Then I started the thread because I didn't know what to think ?
Maybe it'll get better after a few more cycles?
If not, I guess I'll do exactly what you said. Run it till it looks like a MaxAmps packs
DCastaneda
Speed Addict
DCastaneda's Avatar
05.23.2010, 07:07 PM
I've had a similar experience with a Zippy pack. Storage charge the pack so all cells reach the same voltage, and then raise your cutoff voltage a tad. chances are the individual cells vary in capacity to some extent, and if your LVC is too low, the smaller cells dump out and you end up with a severely unbalanced pack. Let me know if it works
Durango DESC410r MMM CC/Neu 1410
B4.1 Worlds MMP RevTech 17.5
SC10 MMP RevTech 17.5
XRAY T2R MMP Duo3 10.5
SC8E MMM CC/Neu 1520 6s
Inferno GT HV- W.I.P. 12s CC HV110
  Send a message via AIM to DCastaneda
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.23.2010, 07:45 PM
LVC is set at 3.40 and the charger has the same reading on display for the #1 cell when charging cycle starts. Should I consider a higher VC amount even though it's at 3.40 ?
pinkpanda3310
pinkpanda3310's Avatar
05.23.2010, 07:53 PM
Have you thought about charging the cells individually through the balance tap? Maybe do a cycle on each to see if there is a mah difference like mentioned.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
05.24.2010, 08:33 AM
PP3310,
Fine suggestion , one I def will consider if this problem persists after a couple more cycles.
Thanks
