I need to not exceed 4 cell lithiums or I have to buy a new charger.
I do want to stay under 14 for NIMH. Have not decided which way I want to go yet on batteries.
I am leaning toward 14 cells NIMH for the heat laps then lipo for the mains.
I want to stay with the 4wd class for now and might move to 2wd later (after I figure out how to drive ok).
I actually might sell the emax and get an XX4 losi. Anybody want to trade??
i have a xxx bk? on 4s or 12-14 cells i would go with the feigao 8xl or 9xl. it will give great runtime and have plenty of power but not to much for a small track.
i would stay away from the novak hv bl i have had 2 and have been nothing but trouble thermal shut downs all the time does not matter witch gears i tried. if you want to blow the doors of the tmaxx an xl 8 with a warrior esc but be prepaired to do some upgrades
warrior 9920 and an 8XL would be a good choice. But as G-man has stated - power costs. Upgrades are gonna be right around the corner. But that is the fun part if you ask me.... And welcome to the forums..
talk to mike . he put me on to his [a list ]and i have not looked back.The “A” list would be as follows:
Warrior 12020 controller
Wanderer xl8 motor
“xl” heatsink/clamp (silver or blue available)
UBEC
Strobe slipper/spur/pinion
5.5mm bullet connectors
i already had mip axles and another good thing would be Maximizer 7075 Aluminum diff cups you can get all this stuff from mike. do that and you will have 1 mean truck . with no regreats:018:
Ok What size is the shaft on the 8 XL. Also what gear should I get. Want one to run all day on 6000 ION cells and 1 for racing at the track (long track)?
I was going to get the wander 10L for run times but they are not in stock.
I suppose the 8XL is fine but I think it will have to much power and be breaking stuff all the time.
O yea I will be running 5s 6000 MAH Lithium ions that metal man found.
