My MMv3 is back, thank you Castle.
nuz69
nuz69's Avatar
My MMv3 is back, thank you Castle. - 05.31.2010, 11:51 AM
Hello, here it is, back from warranty repair, with the refurbish mention :
As you can see, the support team soldered bullet connector on the plate for the battery and added new wires, there is a reason for it ?
Anyway the Castle support team make this hobby very enjoyable, continue your good work and thank you.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
05.31.2010, 04:05 PM
Castle opted to hardware the battery connectors - I believe this was to eliminate any risk of batteries being shorted if someone pulled out the leads.
My guess this was a "fix" for your model which has the sockets on the battery side.
nuz69
nuz69's Avatar
05.31.2010, 04:31 PM
You mean Castle solder it to my plate or simply replace by an ESC with this connector ?
05.31.2010, 05:01 PM
Depends on what your issue was - repairs/warranty ESCs can come back as a remanufactured unit - I've have this in the past.
bryan
bryan's Avatar
05.31.2010, 07:07 PM
I have only had one MMM failure and my replacement was labled new stock on the negative "black" battery wire.By the way, CASTLE CREATIONS has awsome customer service and support.
pinkpanda3310
pinkpanda3310's Avatar
06.01.2010, 07:29 AM
I found, once I had been through a castle after service it was hard to decide on another brand....too hard
06.01.2010, 07:49 AM
Castle service is why I only have cc controllers and motors on all my rides..plus, they are top notch quality components
nuz69
nuz69's Avatar
07.23.2010, 06:10 AM
Hello,
Just to do an update, received my MM v3 (or v5?) from warranty today ! Thanks you Castle !
NuZ
