Efficiency
sabongi
Efficiency - 06.09.2010, 09:40 AM
Guys from Castle, can you post efficiency charts for your motors?
Pdelcast
Pdelcast's Avatar
06.09.2010, 05:25 PM
I guess I have to ask, what kind of an efficiency chart?
Something like this? Or do you want a full torque/eff curves?
This is from the current production 1515, at 15.4V: Vertical is efficiency, horizontal is torque output in newton meters.
At 200W out, eff is about 80%. At 400W out, eff hits 90% and stays above 90% to over 1000W.
However, be aware continuous output power is not this high -- the motors cannot shed 100W of waste heat for long. :)
These motors are designed for low continuous power, and high efficiency at high (intermittent) output power.
Also, please note that this is running through a gear (our dyno cannot run at 35000RPM) -- so the efficiency is actually a few percent higher.
Patrick
Patrick del Castillo
President, Principle Engineer
sabongi
06.09.2010, 10:13 PM
was thinking about efficiency X RPM, so we can gear properly :D
Pdelcast
Pdelcast's Avatar
06.10.2010, 12:14 AM
Hmmm, well motor efficiency can't be plotted against RPM. Efficiency is based on power, which is torque X RPM. You can plot efficiency vrs RPM with a constant torque but that by itself doesn't mean anything for gearing.
Efficiency with no load is zero at any RPM (because no work is being done.) So it only makes sense to measure efficiency on a torque curve.
Gearing shouldn't be based on an efficiency curve anyway -- it should be based on RPM -- and like I said, RPM by itself doesn't have anything to do with efficiency. It only makes sense when you know both torque and RPM.
I recommend that you use Brian's excellent gearing program, you will do much better in the long run. :)
himalaya
himalaya's Avatar
06.10.2010, 05:48 AM
Good topic. I was always hoping Castle lists more technical data on its website or somewhere else like here in the RCM forum. Lehner as an example, they list full test data for pretty much their every motor product, so that the customers know exactly what the product is capable of. (You know Germans)
There are a LOT nerd-heads love to read technical data. The data is much more persuasive than any word, it makes your product more competitive, makes your customer more confident.
....What a Blue Sky....
nuz69
nuz69's Avatar
06.11.2010, 07:28 AM
35 000 RPM = 583 RPS
583 x 1 = 583 watts no? Then 1 on horizontal means 583 watts?
Unless horizontal is kW output? Maybe a little less because of the rpm drop due to load ?
Anyway we love these kind of curves, plz give us more if possible ;) ! For the other Castle motor for example...
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
06.12.2010, 12:05 PM
Power is equal to nm * radians per second, not rotations per second.
So you calculate rotations per second time 2 times pi, then multiply by the torque. That gives watts.
nuz69
nuz69's Avatar
06.12.2010, 12:16 PM
My bad ^^ Let me do this with the old way. A force of 1N at one meter of center, mean the work of this force is :
2*PI*1*1 = 2PI. The power is work / second. In one second, the work is :
2PI**1*1*583 = 1166x PI = 3662,989 J/s = 3663 watts ???
nuz69
nuz69's Avatar
06.12.2010, 05:05 PM
Unless a heavy drop in motor RPMs like 35000 to ~9000, but I don't think that such RPMs drop is possible, even at 3000Watts.
