Will the Kyosho plastic spurs fit in the Jammin X2 CRT?
Bmr4life
Will the Kyosho plastic spurs fit in the Jammin X2 CRT? - 06.09.2010, 01:01 PM
I have the truggy on the way, worried about how loud it will be with metal on metal gears.
George16
Supermaxx
George16's Avatar
06.09.2010, 05:14 PM
Yes it will.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Bmr4life
06.09.2010, 05:39 PM
Thanks, I plan on getting the RCM CRT mount.
Gallagher
06.12.2010, 09:42 AM
You need shim the diff, since the diff will move backwards or forwards a little bit more than when you use the stock spur gear. I use washers to shim the bearing and the diff mount.
scarletboa
scarletboa's Avatar
06.16.2010, 01:09 PM
+1
that is how i shredded my center diff on my crt x2. i didn't shim it and the gears did not mesh right, so they wore out pretty fast.
