Kershaw E-Savage trans
jamesban
Kershaw E-Savage trans - 06.25.2010, 01:34 PM
Has anyone tried this? I spent a buttload of money upgrading everything on my e-savage to metal and now the trans cant handle it. I see no other offerings from any other company for an e-savage trans solution either?
TexasSP
Something, anything, nothing
TexasSP's Avatar
06.25.2010, 03:34 PM
All metal equals heavy truck, heavy trucks equals more drivetrain stress.
No one on here is to fond of anything kershaw puts out. It's all pretty junky hack job products IMO.
The problem is that the e-sav was never really built to handle more weight or power than stock. There have always been issued with it especially the diffs.
www.cubicle101.com
jamesban
06.25.2010, 03:38 PM
My diffs are rock solid. I have the gcm twin diffs for it.
06.26.2010, 12:09 AM
well, the same style kershaw transmission has proven weak and a waste of money in a savage. I don't think the slight weight reduction of the e-savage is enough to make this transmission a viable option.
IMO
jsr
06.26.2010, 01:45 AM
Go to e-savage.com and ask around there. There are a few members that have converted to an all-metal tranny using gears from other vehicles. You should be able to find all you need there.
I've only had experience with Kershaw's diff shims for the e-sav and while it was fine, he ripped me off on it, so I can't recommend him due to his business practices. Sadly, there are many that continue to buy from him.
jamesban
06.26.2010, 10:01 AM
I have had a forum account for over a year at e-savage.com but am unable to post or reply so that's not an option. I sent an email to the admin and never heard back.
06.26.2010, 10:12 AM
you could use an RCM center diff mount and put in a center diff.
http://www.rc-monster.com/proddetail.php?prod=rcmcdmm
jamesban
06.26.2010, 10:37 AM
Im not that talented
06.26.2010, 04:21 PM
Wouldnt a flux tranny fit with a little persuasion?
TexasSP
TexasSP's Avatar
06.27.2010, 04:41 PM
Haven't some guys used the 3905 maxx tranny as well?
www.cubicle101.com
vokus
CNC Machinist
06.27.2010, 10:28 PM
You can send me a nice model of what you want, or a clear print, and I can cnc it for you....
Im currently working on some sick motor mounts, I will post pics if the customer lets meh...
jamesban
06.29.2010, 04:28 PM
Using a 3905 trans sounds awesome but I couldnt find any info anywhere on the interent about that working or how to do it? I might try to tackle the metal gear mod thats on e-savage.com For now I just geared down a little and loosened the slipper a tad and its not clicking so much now.
06.30.2010, 10:15 AM
Some L shaped brackets & a little imagination is all that requiredt o fit a different tranny to any vehicle, assuming theres enough room for it & all the other gubbins. I stuck a 3905 tranny in my TXT-1, so it shouldnt be too difficult, justs needs some careful measuring and some basic metal working hand tools.
jamesban
06.30.2010, 12:09 PM
I wish I knew if the 3905 trans will fit width wise between the rails of the e-savage frame. If it does then I could rig something up. I dont want to pay $45 for one to find out it wont fit though. I think the gear ratio is close on the two also.
07.01.2010, 05:13 PM
Here are some rough measurements for you- didnt fancy removing the tranny as its well buried andnot an easy thing to take out without dismantling the whole truck:-
6cm wide, 9cm long ( front to back including slipper ) and 7cm tall ( not including motor mounting plate ).
Should give you a rough idea of whether it will fit easily or not, but I reckon it would- mounting tabs either side are about half way up.
