mmp with 1800kv
fievel
mmp with 1800kv - 06.29.2010, 02:24 PM
I am thinking about picking up an cc 1800kv buggy motor and I plan on running it on 4s. I know some of you guys are running this setup but is seems that the total motor speed of 26,640rpm is a bit low, anything to be concerned about? I thought we wanted to shoot for the 30,000 to 35,000rpm range. if i gear my Ve8 to 22/50 i will have the speed i need but will i lose efficiency? Will the lower kv rated motor be easier on the mmp? any other draw backs to this set up?
Pdelcast
Pdelcast's Avatar
06.29.2010, 02:28 PM
That should work fine with the 1800Kv motor. The 1800Kv motor is a higher torque, lower RPM motor than the 2650 -- so it's usually happy running at lower RPMs with a lower gear ratio.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
simplechamp
simplechamp's Avatar
06.29.2010, 03:57 PM
I had an MMP and Neu 1512/1.5Y (1850kv) in my Jammin buggy and it ran great.
