Is this possible?
Nixpus
Is this possible? - 07.06.2010, 04:35 AM
Oi oi amigos!
Been playing a bit with converting a Savage to brushless and then making it an XL... the usual stuff.
However Im a tad annoyed with the center gearbox. It takes alot of space, dictates where my motor must be, and needs to be upgraded to HD gears in order to avoid breakdowns (my locked in 2nd gear keeps breaking).
So... why not grab an ultra low KV motor strech the axle and let it grab the dogbones directly? Would this work?
Differential Ratio: 3.2222222222222223 (bullet proof)
Transmission Ratio: 1
Additional Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Battery Voltage: 22,2
Motor KV: 331.1565
Tire Diameter (inches): 6.69 (Terra pins)
Top Speed (MPH): 45
If so... Any good ideas in regards to motor?
nuz69
nuz69's Avatar
07.06.2010, 04:41 AM
That might be possible with an outrunner, but by doing that you won't be able to change the gearing anymore, so if you are wrong on your Kv, it's the end...
I recommand you to junk your gear box and to use a center diff setup, with a CD you will have a proper traction and change easily the gearing, if needed
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Nixpus
07.06.2010, 04:50 AM
Hmmm... true there will be no gearing options other than swapping wheels :)
Im not really hot on a center diff... I want wheelies! But maybe an axle with the spur gear directly attached (maybe a working slipper as well)?
bigboi146
Multi Tasking
bigboi146's Avatar
07.06.2010, 09:40 AM
You can still wheelie with a center diff. Just throw some thicker oil in it.
mckrill
Technology Explorer
07.06.2010, 09:42 AM
I have seen a few out runners mounted like that, to replace the center diff. Success has been mixed from what I understand.
If you go HV you could potentially change the gearing by adding or subtracting lipos...
Not a very fine adjustment, but... Example 10s => 11s etc
